RESQ-MYTECH
So, quick info first..... Lenovo Ideapad 500s-13isk. no power to the board. Narrowed down to a blown diode. Can not find any info at all anywhere on this component. Not to buy, not to get spec's, not to get equivalent. Designation on the board is PD303. Got one other on the board that is designation PD101. Don't want to move the diode from 101 to 303 as they are all on the power circuit and moving it could possibly still leave me with a non functioning board or worse, it blows and I end up with 2 non replaceable diodes. Unable to locate a schematic to get more info.
What I have found is, ( i believe this to be correct but who knows) it is a Schottky diode, SOT23. Markings on the one that has not blown is 3D with a dot below and a 7 on its side with 2 dots below. I know that 20v is present on the bottom right leg. No reading on bottom left or top legs. I also do not know the pin outs as what ever combination I place the probes on the multi meter whether in circuit or out, I get a quick beep. i.e. red bottom left black bottom right or top/ red top black bottom left and right/ red bottom right black bottom left or top
Information from SMD-codes shows this, but I fear it is not the right info :-3D RB715F Si-diode Dual, Schottky Rectifier, 40V, 30mA, Vf<0,37V(1mA), 5pF SOT-323 16dg 3a - Rhm,Trs
I have attached a pic of the good diode.
Any information or help that I can glean will help me massively.
