Post-repair testing - how far do you go?
Depends. If it's something obvious like you said, I call it good. I typically run ASD or internal diagnostic after all repairs. On things like U8900 on 3332 or extensive liquid damage repairs, I typically stress test them.
I test everything of course. Boot OSX, test all keys, test iSight, check battery status, set clock correct, check BT, WiFi. On machines with GPU run "Heaven" for a few minutes.
I test everything, nothing worse than a returning customer because you forgot to plug shit in or keyboard is screwed. on off button not working. when a customer returns because of a fuck up they usually want it done on the spot, its not worth the hassle. good practice would be to have a standard checklist that consists of a 5 min check. document the check in the invoice as well to safeguard yourself.
I'm with the test everything group and agree with PCTRONICS about the dreaded returning customer. I also use a word document with a checklist that I go over with the customer upon pickup. It takes five minutes to run the manual peripheral test as opposed to ASD. (See attached Doc)
I keep a copy in the customers file in case they develop amnesia a few months later and use the argument "It was like that when I picked it up' or "I never used it since I picked it up..... it was in the closet until today" The fact that I leave a copy on the desktop also helps keep them honest.
Another good reason testing all the peripheral's is there could be another issue they forgot to mention. I had one yesterday that had a bad camera on a MBA, when I went through my checklist with the client he acknowledged it was broken and didn't use it. I didn't get an additional repair but It is now documented that it was a failed camera before it came to my shop.
I usually run a yes command in multiple terminal windows to heat things up after I do a thermal, but I will try Dukes preferred Heaven on GPU models.
