Power issue on a MacBook Pro A2485 (motherboard: 820-02100-A)
datatech85
Hello,
We received a Macbook pro A2485 which has a power issue. Battery doesn’t take charge and all the USB C ports are stucked at 5V / 0.018A. We can’t get 20V.
The Macbook has already been to a repair company and we note that the UG400 chip has been unsoldered.
Here are the operations we have carried out:
- Replacement of the CD3217B12 chip “UG400”. We know that this type of chip is programmable and that it's essential to have a chip from an identical motherboard in the same position. We found this chip on Aliexpress, which comes from the same motherboard.
- Voltage measurement across fuses F5200 and F5201 = 0.23V
- Voltage measurement on the PPVBAT_AON_CHGR_REG rail when the fuses F5200 and F5201 are removed = 12V
- Voltage measurement on the power rails of the CD3217B12 “UG400” chip (Result attached)
We assume that the USB C chip we replaced is possibly dysfunctional but we would like to be sure before ordering a motherboard.
Do you have any other leads on the origin of the failure?
Thanks in advance,
As per names, UG400 is paired with JG600.
Is irrelevant to cheack voltages on UG400 connecting the charger to JF600.
Check diode mode to ground at PPBUS_AON and 3V8_AON power rails.
Any history available?
datatech85
Thanks for your answer.
I checked in diode mode PPBUS_AON and PP3V8_AON power rail.
It seems that both rails are shorted (or at least low resistance).
I've got 26,7Ω on PPBUS_AON and 29,5Ω on PP3V8_AON.
Regarding the history, we don't have any informations on the operations carried out by the previous repair company.
Any leads ?
That's strange.
Seems to have problems on both power rails.
Check if any big coil gives same reading to ground as PPBUS_AON.
Don't forget LN480/980.
Use ohm scale, as always for low readings.
datatech85
I checked all the big coil.
No one gives same reading as PPBUS_AON.
Only L5840, L5820 and L5800 gives the same resistance that i already checked on PP3V8_AON but it's not surprising so far.
Any suggest on components to check ?
