(RESOLVED) 820-3208-A, burnt cap on PPBUS_S5_HS_COMPUTING_ISNS, replaced, then 2 weeks later burnt cap on PPBUS_S5_HS_OTHER_ISNS
joshAU
Hi all.
I have an A1465 Macbook Air with a 820-3208-A logic board that is dead.
I recently had this unit it, dead, and found C7510 on PPBUS_S5_HS_COMPUTING_ISNS Rail was visibly damaged - burnt, and had shorted out that rail.
I removed it, the short was gone, so I replaced with another from a spares board.
The unit appeared to work perfectly, so I returned it to the customer.
Two weeks later, the customer brings it back in, dead again.
This time there is a damaged cap (C7284) on PPBUS_S5_HS_OTHER_ISNS, that is burnt, and shorted.
Both PPBUS_S5_HS_COMPUTING_ISNS and PPBUS_S5_HS_OTHER_ISNS show a short to ground, however after removing C7284, the short has disappeared.
What should I be looking forward that would cause this?
I could just replace C7284, but I suspect something is drawing too much current?
Or is it just bad luck/timing?
Any suggestions greatly appreciated.
Strange to happen so quick in time; but could be just bad luck.
Did you check the exact PPBUS_G3H, without battery connected?
joshAU
Update:
OK, above measurement was at F9700
If I measure PPBUS_G3H on pin 1 of F9700, the figure is ~4 volts.
This is the same as pin 2 of F7040.
HOWEVER, pin 1 of fuse F7040 measures 8.42 volts as it should for PPBUS_G3H.
I thought fuses either worked or they didn't?
I removed the fuse, and it measures 15 Ohms?
Weird.
I replaced it with another from a spares board, and unit is now running, boots to OSX, and seems fine.
I haven't yet replaced C7284
Thanks again for your help 2informaticos, I appreciate it.
