[SOLVED]820-00165- Won't Start off the battery.... Stumped
TCRScircuit
Super Moderator
It won't Start even if all of that is unplugged. I have the board on my bench and when I plug the battery in the board does nothing... No fan spin unless i short the pins... If i plug the charger in it starts fine,
That is normal. When AC is connected after all power was removed the board auto powers on. When on battery or after a shutdown you need to press the power button.
TCRScircuit
Super Moderator
After more diagnosing, the board operates normally with they keyboard flex cable unplugged, however, when the keyboard is plugged in, the board won't even start if I jumper R5115. So what would cause it not to start with the keyboard plugged in?
A bad keyboard....
You can test with any apple unibody keyboard to see if power button works, they all have the same pinout.
TCRScircuit
Super Moderator
I cleaned the cable, It starts now with it plugged it, but immediately you can smell burning board from the trackpad area.
I assumed you check the trackpad to board cable. The cable is fucked if it is corroded. If it has been burning the connector is also probably fucked now. Clean everything up and try with a NEW cable.
TCRScircuit
Super Moderator
Thanks for your help Duke. The new cable still burned and after looking at the trackpad logic board under the microscope it is fucked up bad. Sold customer new keyboard and trackpad.
