SOLVED: 820-02020 stuck on 5V 0.03A
SoloHarty
We have an M1 MacBook Pro in right now that is stuck on 5V. Customer states it ran out of battery then wouldn't charge. The board is clean with no signs of liquid anywhere.
I have tested all LDOs and none have shorts, I am getting 12.28V on PPBUS_AON but 0v on PP3V8_AON.
No shorts that I can find and It's not picked up on Apple configurator. Is there something I'm missing or am I going in a completely random/wrong direction?
Thanks
3V8_AON must come on.
DFU requires some voltages derived from 3V8_AON.
Check U5700's basic voltages: pins 8, 6, 7, 5, 12.
Thanks for the quick reply.
U5700:
Pin 8 - 12.28v
Pin 6 - 0v
Pin 7 - 0v
Pin 5 - 0v
Pin 12 - 0v
Pin 8 is getting power but everything else is reading in low mv (60-100mv) but it's the same even when I'm not measuring so I'm assuming its just my multimeter.
EDIT: No shorts on any of those pins either.
Yes R5710 seems to be 0v on both sides. Strange thing, I left it plugged in for a while while I done other repairs and now PPBUS_AON is hard short to ground, definitely wasn't before and U5700 heats up like crazy when I inject 2v to PPBUS_AON. Could a bad u5700 be why I'm getting no voltages?
Removed U5700 and short is gone. Will dig through my donor pile tomorrow to see if i have one. If not then will need to order it in. Could a bad u5700 be the reason i’m missing voltages on the other pins and on both sides of R5710?
Ok, so got 2 donor boards in today that were iCloud locked boards. Both boosted to 20V so I took U5700, U7000 & U5340. Now I get all voltages but the Mac still won't boost as PP3V3_S2SW_SNS is shorted and causing UC810 to pulse. Removed UC810 and injected voltage but nothing is getting hot except my leads. Can't find where this signal begins or if it's just the universe telling me it's toast!
With UC810 removed, I get 20V but not sure if this rail is an offshoot of another as I can only find enable signals and IN voltages for it.
We can mark this one as solved… for some reason. Left the board overnight on the desk and when I went back this morning, short was gone. Replaced UC810 and now Mac turns on and everything seems to be functioning properly! Didn’t realise UC810 is actually responsible for that power rail but no idea why the actual pad underneath was shorted in the first place.
Thanks for the help!
