[SOLVED] 820-2850 backlight
samiam
had liquid damage, fixed everything else up to this point
replaced C9560, C7241, C7282, C7281, L9000, C9010, F9800,C9802
R9808 and R9809 but the last two are reading at ~100k in circuit instead of their proper values
PPBUS_S0_LCDBKLT_FUSED 12.6V ok
PBUS_S0_LCDBKLT_EN_DIV reading 6.31V
at first it starts at proper 4.21V and then jumps up to the 6.31V
Is it Q9806 or am I looking in the wrong place, the LVDS connector is questionable but seems to work.
J
jason_microsoldering
Guest
Voltages on pin 4, 8, 22, 23 of U9701?
Voltage drop to ground on C9797?
larossmann
Just to clarify, is Q9806 not opening? Why are we looking at PPBUS_S0_LCDBKLT_EN_DIV? If it is not opening, what are LCD_BKLT_EN and BKLT_PLT_RST_L ?
samiam
PBUS_S0_LCDBKLT_EN_L 3.42V
BKLT_PLT_RST_L 3.3V
LCD_BKLT_EN 3.3V
U9701
pin 4 negligible mv
pin 8 3.3V
pin 22 and 23 both 4.96V
larossmann
My vote is bad Q9807 as well. It's dual N channel meaning if voltage on gate is equal/higher than source it should let power flow meaning tat if LCD_BKLT_EN & BKLT_PLT_RST_L are 3.3v than PBUS_S0_LCDBKLT_EN_L should be ground. 3.42v is not ground!
The voltage on pin 4 of U9701 comes from the voltage divider of R9731/R9715 whose power is sourced from PPBUS_S0_LCDBKLT_PW which comes from Q9806 which will not open so long as Q9807 is not opening and allowing the voltage divider of R9808 and R9809 to drop Q9706's gate voltage to ground. Q9706 is a P channel and will open when voltage on gate is sufficiently lower than the source.
Replace Q9807!
aprendiz
Moderator
The voltage on pin 4 of U9701 comes from the voltage divider of R9731/R9715 whose power is sourced from PPBUS_S0_LCDBKLT_PW which comes from Q9706 which will not open so long as Q9707 is not opening and allowing the voltage divider of R9808 and R9809 to drop Q9706's gate voltage to ground. Q9706 is a P channel and will open when voltage on gate is sufficiently lower than the source.
Replace Q9707!
samiam
ok I did Q9807 and PBUS_S0_LCDBKLT_EN_DIV stabilized properly at 4.21
Q9806 was still reading nothing on left pins to inductor
did Q9806 (and a jumper to the fuse since that line seemed unreliable) and now it looks like it's all good
