[SOLVED]820-2915-A-No detect battery-no water damage.
The replacement SMC?? If yes, will know once you put it on the board.. or if you can test it on original board before remove it....
before remove it....I would like to know if it's possible to detect with mesures if the SMC is anormal or dead..... just a question
testing all PP3V42_G3H one problem (picture)??? (all points = 3.46V except R8798)
there is no way to tell if the SMC is good or not without trying it, just pray. even if i send 16v to battery detection lines it gives me same measurements to ground half the time as it does when it works. the -A -B board shit matters nothing in terms of any of the parts you are stealing from them to my knowledge.
SMC original, reball, test failed same result....
SMC 2---- F***K dead.........I have damaged it at the time of take off(desoldering).
SMC 3 YOUHOUUUUUUUUUUUUUUUUUUUUU
Now Macbook it displays the battery on OSX, but battery is dead, and (battery led indicators is ok but blinking when I press it...)
NEW genuine battery and let's go????
it's ok to you?
:rolleyes::rolleyes::rolleyes:
