[SOLVED]820-3115 - Can't see battery.
gcain
CS laptop needs a new battery, but it can't see any batteries.
Board is practically spotless. In diode mode, SDA is 0.196v and SCL is 0.400v . 17/18 and 20/21 of the U7000 measure okay.
Measure against a working board, SDA should be about 0.400.
We looking at an SMC replacement?
gcain
I replaced U7200 and we have a battery back.
Haven't seen that behaviour with a faulty U7200, or maybe I just forgot.
Edit: After a few minutes the green/orange light is switching every five or ten seconds. Could this be bad soldering.
I looked closely and it seems all the joints are nice.
PPBus is back to 12.25v
I must have disturbed what ever the issue was for a moment. I don't even get an orange light at all any more.
aprendiz
Moderator
This could be a bad U7000, bad SMC, corrosion on BIL connector, bad BIL or corrosion under battery connector, first remove BIL and inspect connectors (battery and BIL)-----replace U7000----replace SMC
gcain
Sorry, I meant U7000.
BIL looks spotless. I have replaced U7000 and everything worked as expected for 10 of 15 minutes then slowly deteriorated back to the original behaviour.
I can swap it again, but would rather not tear through all my U7000s.
Originally when I removed U7000, diode on SDA went back to ~0.400, but now when I remove it, the measurement remains at ~0.200v.
I suspect there is just a short, that I managed to disturb somehow when I first swapped U7000 out.
gcain
It seems to be moving up and down freely, as if there is a pull up or pull down resistor missing.
dukefawks I was just looking at this board closely and I noticed the green light appears to be flashing really quickly.
gcain
I've already replaced U5010. Just sent a ton of flux under SMC and seems to be working again.
We'll just have to see for how long.
Thanks Duke.
Edit: board is braindead now.
This repair hasn't gone to plan. :'(
gcain
Just came back to this board.
I ended up running flux under the SMC again and heating until it was dancing around with the air.
Board gets a picture again and charges a battery.
Mark solved please.
