[SOLVED]820-3115 green light no boot
gadgetfix
hey all.
no boot no chime no fan spin
got .6v on ppbus_g3h
and nothing on pp3v42
16.5 on ppchgr_dcin
nothing on L7030
is u7000 dead?
EDIT: no green light
yes and i should point out no previous water damage? customer reckons they had trouble with the charger and it died?
UPDATE: short on pp3v42
There is a big chance that U7000 is dead, SMC is dead and something else, but lets start with pp3v42_g3h...
Resistance to GND?
this might be dumb but can i use the pprobes on my multimeter and connect to dcps and inject that way?
and how come r6990 need to be replaced even though it shows 16.8v and ohms are only within 5% tolerance
ok so after injecting 3V i found L6400 heating mega.
now after removing i wanted to make sure the short on pp3v42 is not short to ground so i test pin 2 L6995 and no beep so its all good. I replaced L6400 and again short. So i removed and check the other end of L6400 which continues as PP_AUDIO_CHS and its short?
what am i doing wrong? could there be multiple shorts to ground OR L6400 is faulty OR something else?
Nope same chip. Is 3v42 now 3.42 volts? If so, I’d say check resistance to ground on PPBUS and see what you get.
