[SOLVED]820-3209 spotlight effect on half of LCD
Revive
LCD as pictured with alternating dim LED's on left half of screen.
Backlight driver looked suspect so I replaced it, there was some corrosion on the LVDS connector so I replaced that too.
No change in the issue, I tried connecting a different LCD and it persists so it's not the LCD or cable itself.
PPVOUT_SW_LCDBKLT: 24.7
LED_RETURN_6: 4.7
LED_RETURN_5: 1.6
LED_RETURN_4: 1.6
LED_RETURN_3: 1.6
LED_RETURN_2: 1.6
LED_RETURN_1: 1.6
Any ideas what to check?
Best Regards
S.
Revive
I wasn't sure if LED_RETURN_6 was high or all the others were low, but I suppose its more logical its just LED_RETURN_6 thats the issue.
the BKL_ISEN6 pad was in good shape and the ball looks good, the only pad on the driver that looked iffy was the center TP_BKL_FAULT Is it possible that could be causing this issue?
I already replaced R9722, no change.
