ytesfay80
This board initially was just a no backlight issue and there was liquid damage around the entire lcd connector area as well as the lp8550. I replaced all the components in those areas and after all this now the fan does the usual on and off fan spin 3 times but after about 1 second the fan stops spinning. PPBUS_G3H is 8.6v and once the fan stops spinning o 5v_S5 and 3v3_S5 rails are present.
There was also liquid damage to the JTAG connector which I removed. I thought the issue for this fan spin may have been because I found that Pins 30&34 of J6100 were bridged together but even after fixing that the issue remains.
C5120 did not look good so I replaced it along with U5110. All the proper voltages are present on U5110
I replaced C5003/09 because they didn't look to well.
There was a little corrosion around U6100 and U1900 so I put some flux and heated that area.
U1950 and its area looks fine and I get 3v42 on C1950 even when the fan stops spinning.
It is doing all of this with no external components plugged in.
