[SOLVED]820-3437 no red light
arnonabuurs
I have a Air 13 inch with no red light on the charger, only green. I know it means it has no feedback from Sys Onewire, but how do I go about to test it on an Air? I know how it works on a pro. Got some values:
PPBUS_G3H at F7140 - 8.17v
PP3V42_G3H at C5120 = 3.42v
PP3V42_G3H at BC_ACOK Pin 14 U7100 = 3.39v
CHGR_ACIN Pin 3 U7100 = 5.27v
How should i trouble shoot this?
PPBUS is a bit low, seems SMC is not working properly, check sense resistors on ISL if everything is ok my next guess is SMC.....
There was indeed some corrosion, we have replaced C5008 it looked like one drop on that IC but indeed might have leaked under the SMC, SMC_RESET_L = 3.417v and R7100 = 0 ohm
The usual, check for a pulse after connecting power on PP5V_S4RS3. Is it power cycling? Check resistors/traces around U6100, could still be more crap under SMC.
