Hi, i have and A1278-2936 Board with green light at the charger.But ppbus_g3h is 1.6volts i even change u7000 and still same problem.What do you recommend? Please see my attachment for the rail i have checked.
What is the resistance to ground on F7040? What is the resistance between pins 17/18 of U7000? What is the resistance between pins 27/28 of U7000? 1.7v is magic number for short to ground or bad charger side current sensing(pins 27/28)
No you don't understand, I'm asking for resistance not diode mode. But diode mode provided enough info here. Pin 27/28 should have 20 Ohms between them. So you either have a bad R7021/22 or a bad trace in that circuit.
okay i got some where wow you were right r7020 resistor had a bad trace that would not give me ohms reading on r7021/22 now i get 20 ohms after i made a jumper from r7020 i get now 12.6 and fan spins the only problem now mac come on then shuts off then comes on for about ten seconds i tried to smc reset and pram didn't work am thinking bios or maybe something i miss over look what you thing and thanks so far.
