TLDR: Aside from replacing the DC IN board, does anything below indicate need to replace ISL6259 IC? Is there a way to test the charger (60W) to see if the cable needs replacing? (No fraying or exposed wiring, but the cord bends too easily just outside the rubber nipple at the brick.)
I have a 2011 13" MBP that won't charge or power on. I can't find any usable voltage anywhere on the board so I tested the DC IN board (820-2565-A, which looks rough). Here's what I got:
I also measured Volts on U6900 & U6901 and got the following:
SYS_ONEWIRE - 0.5mV falls to 0.2mV
SMC_BC_ACOK_VCC - 0.1mV
SMC_BC_ACOK - 13mV falls slowly to 0.2mV
PP3V42_G3H - 0.5mV falls slowly to 0.2mV
The logic board was dusty but after gentle cleaning (soft ESD brush, NOT toothbrush, + 99% Alcohol) I don't see any obvious signs of burning or corrosion. The DC IN board itself looks OK but the MagSafe connector looks rough - signs of cracking & exposed pin surface.
I definitely plan to replace the DC IN board. Does anything in the above readings indicate need to replace ISL6259 chip? (This would be my first microsolder attempt and would rather skip if it can be avoided.) Is there a way to test the charger? It's genuine and a bit dirty, but no frayed/exposed wires. The charging cable bends too easily just outside the rubber nipple at the brick.
As advised in the Rossmann Repair Training Guide, I did NOT use my genitals to check for thermal issues.
Thanks!
| Pin | Name | Volts | Ohms | Continuity to Ground | (Unplugged) Cont to Gnd | (Unplugged) Ohms |
| 1 | PPV18V5_DCIN_FUSE | 0 | .3 | Yes | No | 1.85M |
| 2 | PPV18V5_DCIN_FUSE | 0 | .3 | Yes | No | 0 |
| 3 | GND | 0 | .1 | Yes | Yes | 0 |
| 4 | GND | 0 | .1 | Yes | Yes | 40k |
| 5 | Adapter Sense | 0.3V | 350k | Yes | No | 40k |
Thanks!
