SOLVED: A1466 820-00165 - Missing PP5V_S5 and PM_SLP_S5_L
it-solve
Not turning on, managed to turn it on after cleaned little bit of oxidation around SMC and with SMC bypass. Worked for a bot and stopped turning on.
No current draw
PPVRTC_G3H = 3.41V
PP5V_S5 = 0V
PM_SLP_S5_L = 0V
No visible short or damaged traces/components
Not sure why but now I get SMC_RESET_L = 3.39V, but it ws still 0A power draw.
I went and touched up the resistors around the SMC as they had some minor oxidation appearance.
Now I get 0.18A, no fan spin. It takes a while until it starts pulling any current.
I get around 45*C / 30*C areas on these two components
U7320- I replaced but still does the same hot spot
U3900 - Top right corner around PIN1 is warming up too
reballed and replaced the SMC, was clean underneath. 0.18A and same heat pattern as the IR screenshot
