Sykulski
After wasting time to figure this out I thought I would share. It's a MBA13 - 820-3437. I had 4 sensors failing: "CPU Proximity", "Charger Proximity", "S2 Camera Proximity" and "Input Air Flow". Machine running slow with full speed fan. I wasted time checking all these sensors just to find out everything looking normal. Then I tried making the sensor test without camera cable connected. And guess what... All sensor errors are gone! When I connect camera cable the 4 sensors fail again. So remember this next time you have weird sensor problems - disconnect camera before you go spending time on troubleshooting other sensors Also "S2 Camera Proximity" sensor stops failing when cable for the camera is unplugged
