*SOLVED*IMAC A1418 2014 820-4668 not booting
donnos
Hello,
I have a 820-4668 not booting, after a few measurements, don't see obvious short or any heating.
I have the 1st LED but when pressing power botton has no reaction.
my confusion is that in no_boot state i have S5 state power rails(which i do have). but the board is pushing out PM_SLP_S5_L(3.3v) which is S4 enable before power button is pressed, Is this normal?
i have pp3v3_s4 but no pp5v0_s4. should i start my troubleshooting here? pin 24 of U7600 is 3.1v but no pp5v0_s4 output
"i have pp3v3_s4 ... but no 3v3_s4 output"
What we should understand there???
The board must start by itself when power is connected.
However, if stuck in S5, you can trigger SMC_ONOFF_L and check for reaction at PM_SLP_S4/3_L signals.
12V_S0_FET pulse at least at the same time?
Q8450 is a common failure in these boards.
donnos
typo there i i have pp3v3_s4 but no pp5v0_s4 even when pin 24 of u7600 is enabled.
SMC_ONOFF_L can be triggered when power button is pressed.
so seems i'm going past s5 state. i have PM_SLP_s4 and S3.
12v s0 is constant ON @12V, not pulsing.
PM_SLP_S3_L stays high?
Then various S0 voltages should be present.
Post diode mode to ground at 5V_S4 (L7650).
donnos
Yes some of the s0 power rails are running except for those depending on the 5v rail.
Diode mode reading is 0.165 done at L7650
