[SOLVED]No magsafe 820-2327
MDY
3V42 - stable
Q6920 pin3 and 6 -1V and goes down
SMC_BC_ACOK - 3.25V
PP18V5_DCIN_ONEWIRE - 17V
Do you get 7V aprox on pins 2&5 of Q6920?
Check resistance to ground on ADAPTER_SENSE line.
Check SMC_RESET_L voltage level.
Diode mode should give something. So either a broken trace to SMC or dead SMC.
Actually a broken trace is likely as there is also a pull-up resistor on this line, so if it is not shorted to GND the line should be pulled up to 3V42.
