Water Damaged Macbook Air A2179
I am still having no luck with Restoring BridgeOS on a T2 Mac, I am running MacOS Cataline 10.15.5 and the DFU mode comes up fine so it is detecting the target mac. i am using the latest Apple Configurator 2.13.2 , when I do a revive or a restore I get the following error message, (See picture attached)
Looked over this forum and the internet and can't find what this error means.
I now manged to get passed this error message by unplugging the screen connector , I was then able to run the Revive command, I now need to get a new screen and all should be fine.
Thanks for the feedback about bypassing error removing the internal LCD.
This will help another members for sure.
This error might also happen if Battery has a fault as well. Also below is a good article about how to install MacOS on a portable hard drive that you can boot a Macbook off of.
