I've tried multiple other IO boards and cables. Board will stay running if IO cable is plugged in after it starts. CHecked VSENSE and ISENSE readings related to the SMC. ISL has been swapped. No change in Adapter Sense, SMC LID, FINSTACKSNS_ALERT_L, SMC_BC_ACOK or the SDA/SCL lines with cable connected or disconnected. I'm guessing theres a sensor reading being sent when the cable is connected that prevents the board from starting?
Guessing I need to change the SMC, I tried reflowing it. But I'm confused as to why the board will start with cable unplugged.
