$29 paid forum support. How to access?
jimb0s
A2141 with Service Recommended on battery. I replaced with new battery, Took a full charge yet next day when I checked it - still reported recommend service even though at 100%. charge. Chose restart and came up fine (but same warning). Thinking it might be something else causing warning I decided to just restart and run Diagnostic with just D key. I did not get that far 1) The system shut down abruptly on its own. 2) Unresponsive after that. 3)SMC has no affect and of course cannot do PRAM reset as it does nothing. A dang paperweight. 4) disconnected battery 5)flea power removal. 6)appears dead.
Be sure to use 96/140W charger; with correct cable, of course.
This machine doesn't boot with 87W charger, if there is a problem with the battery.
jimb0s
Sure did and also left it to charge overnight. No auto-start upon screen opening. No power button - regular. Or to remove flea power nor any other reset function.
jimb0s
Why glue in battery with super tacky black strips? Genius! Why put wiring under the MLB? Genius, Apple.
jimb0s
It was busy doing a time machine backup to an old spinning HDD. So now I can move forward without losing data! Yes with DFU it turned on! Thanks for that. Good advice. It turns on with lid opening and button, both.
Yes still the Battery service rec. Also without a battery it starts and still reports battery needing service. I thought it would indicate NO battery.
jimb0s
The small zigzag cable from battery circuit board to MLB is missing and circuit board connector that accepts that cable appears to have been damaged.
jimb0s
Cable is in place. zigzag cable with a white dot. New battery still says service recommended at the same time it indicates the charge as full at the moment. I will leave the Mac on for a couple hours without the charger and check if anything changes.
