820-00045 20v 160mA
I managed to get the board to work by heating the CPU. Booted up and I had display.
Shut it down to reassemble and tested again but would not come on.
Board now stuck at 20v
Draws 220mA for 5 seconds then drops to 160mA and stays at that.
Would an SMC reset fix this or am I looking at a problem with CPU?
You can try to heat entire board into IR oven.
If boots and get access to its SSD, recover the data as soon as possible.
No, that is just a preheater.
You can try to heat/reflow CPU as first time did.
Once booted (IF), retrive the data...
