820-00138 fast fans
Kyle93
Arrived with fans running fast. No liquid damage. Tried replacement heatsink, good known trackpad and trackpad cable but no changes.
Apple diagnostic says problem might be with the SMC and HW monitor says heatpipe #2 is 128C
What should be tried next???
Kyle93
This board is pristine looking with no liquid damage all around.
Using a 820-00426 boardview. 820-00138 is still not available correct?
What should be checked or measured next?
00163 boardview may help also.
Try disconnecting RIO flex (J9510).
Check continuity from U5860/70 to their corresponding temp sensors.
Kyle93
u5870 continuity is good. u5860 does not exist in boardview
disconnecting RIO flex had no change.
Unfortunatelly, the boardview is not for this model.
However, U5860 has an internal sensor and should be placed close to left fin stack, on top side (SMC side); as per schematic mention.
Search for Q5803 near the right fin stack.
Kyle93
Found U5860 top left side of board (SMC side)
Replaced but still no change. Also checked all surrounding resistors.
Airport temperature is sensed by U5823.
Inspect for corrosion, resolder it and check R5822.
If still the same, remove it and test the machine again.
