So I got two A1398 2015" with 820-00138 boards from different customers, but with exactly same issue - no backlight (image is present). One of them is untouched, the other one has been worked on, but the other technician couldn't find the solution for backlight and gave up - he replaced LVDS connector, probably tried another U7701 because it's missing, tried another screen (the original screen was working with another board).
What I have done so far:
- tried another known good display assembly (100% 2015 model)
- tried another U7701
- tried another Q7706
- checked LVDS connectors on both boards - they look completely fine
U7701 measurements:
pin 5 = 5,07V
pin 18 = 5,06V
pin 11 = 5,84V
pin 17 = 3,33V
pin 15 = 5,01V
pin16 = 5,00V
PPVOUT_S0_LCDBKLT - 51,2V
D7701 is not shorted
F7700 has continuity
Q7706 measurements
pins 1-6 - 12,58V
pin 3 - 8,78V
pin 4 - 12,58V
I believe boards are fine, as they produce 51,2V output voltage which is present on LVDS connector but for some reason backlight is not turning on...
U7701 measurements:
pin 5 = 5,07V
pin 18 = 5,06V
pin 11 = 5,84V
pin 17 = 3,33V
pin 15 = 5,01V
pin16 = 5,00V
Q7706 measurements
pins 1-6 - 12,58V
pin 3 - 8,78V
pin 4 - 12,58V
