so this machine came with clean board, measured that ppbus_g3h is shorted to ground, so I inject 1.5v there, replaced c7377l, short is gone, but ppbus is still 4v, but not stable, any advice ? idk where to proceed right now,
So you've just injected voltage into PPBUS_G3H BEFORE searching for an shorted high-side MOSFET.
I can only hope you'll fry one board and then stop do this; is probably the only way to learn why.
Two many times I explained the reason, I will not repeat again here...
so I found that q7630 is shorted, I replaced it and the short is gone, fuse's resistance is more than 1 , so I replaced it too, now I have fan spin, and ppbus is 8.6v, but no chime and no image, resistance to ground on L7130 is 0.5kohm
Nvm, board turn on now.. But i still need the answer regarding is mosfet the Q7 bla bla thing? So when searching for shorted mosfet it must be done manually? ( Not by injecting) thanks before for helping 2informaticos!
"I found that q7630 is shorted"
Ton of luck, you didn't fry the CPU injecting into PPBUS_G3H.
"searching for shorted mosfet it must be done manually?"
If already detect the short, just compare readings from PPBUS_G3H with all big coils.
You had EXACTLY the same reading on PPBUS_G3H and L7630; guess what that meant...
yeah because before i found the short, I remove all the caps 1 by 1 and check if the short persist, well it doesnt really take a lot of time, but sometimes, the ppbus_s5_hs_computing_isns's caps doesnt resist the heat quite well and burst ( pop sound , and bad smell coming out of it ).., okay at least I learn something from this, thanks a lot for helping!
