820-00165 Green light, in S0 state, no fan spin
Neil250
Green light on charger/ goes to orange.
No fan spin.
No liquid damage.
PP5V_S0: 4.95V
PP3V3_S0: 3.30 V
PP1V5_S0: 1.5 V
PP0V6_S0_DDRVTT: 0V at pin 1 C2700
U7400
PIN 13 was 0.18V to ground in diode mode but ONLY 336 Ohms in Resistance mode
All the other pins (except ground pins of course) were in the kO range in resistance mode.
U7400
PIN 13: 1.2V
L7430: 1.2V pin 2
I assumed I was in S0 state.
Is there a short on PIN 13 U7400? It seems like very low resistance to ground and I'm not sure if
PP0V6_S0_DDRVTT should be 0 V
Q8150 also looks not good:
You can leave Q8150 out of board.
But shouldn't be the culprit, if ALL_SYS_PWRGD stays high.
Do you get VCORE?
MEMVTT_PWR_EN is required to enable PP0V6_S0_DDRVTT .
Neil250
MEMVTT_PWR_EN :0V at pin 17 U7400
U1970 ----> NO SHORTS
6:1.20
4: 0 V so no output here ----> MEMVTT_PWR_EN
R1970:330 kO
1: 3.3 V
2: 0 V
CPU VCORE: R0860: 0 V
L7320: 0 V on pin 2
U7320
6: 5.09V
1: 0V
2: 4.78
3: 0
5: 0
7: 2.04
1: SHORT TO GROUND ON PIN 1 U7320
CPU_VCCST_PWRGD :0
ALL_SYS_PWRGD: 0.21
PP1V5_S0: 1.50 V
PP1V05_S0: 1.05 V
Neil250
Post ohm value to ground at L7310/20----> 0.3 O
Do you have 3V at pin 7 of U1950? ----> 0 V
8: 3.43
1: 0.12
2: 3.33
U1950 does have corrosion at PIN 3 &4
Clean/change U1950.
If you get some S0 voltages, PM_SLP_S3_L is high.
Something pulls down ALL_SYS_PWRGD; can be U1950...
Neil250
Good news, changed U1950.
Fan spin!!
But still no boot and still 0 volts on L7320
But it feels like progress with fan spin and PP0V6_S0_DDRVTT now has 0.6V
Neil250
U1950 pin 8 looked burned
I cleaned it , pad was still there
replaced the chip
will check voltages
Neil250
U1950
1: 3.33
2 3.33
3: 0.12
5:.90
6: 3.42
7: .66V
pLEASE note I soldered the U1950 on backwards at first, realized my mistake and fixed it
I even used a brand new U1950
That was my clumsiness
This is an AND gate so 5 & 7 have to be 3.42 V correct
1&2 are 3.33 so this chip is not outputting correctly on 7
Neil250
OK now I am not getting anything on 1&2
I put a brand new U1950 in place
8: 3.42 V
7: 0
WTF?
I had fan spin before
even ALL_SYS_PWRGD is 0.1 V at pin 1
I thought i was close but this is bad I think
Maybe Q8150 is bad?
6:3.29V
nothing at pin 4 Q8150
How can U1950 work with no ALL_SYS_PWRGD
Q8150 must be bad?
but redundant?
looking at this post:
Neil250
I soldered and resoldered U1950 5 times.
I even ordered a brand new chip and placed that there.
The ALL_SYS_PWRGD is missing which I assume is very bad if this board has any chance of starting.
Q8150 removal to see if it helps?
Should I go back to measuring all power rails again or maybe look at the generation of the
ALL_SYS_PWRGD signal. Maybe something is dragging it down.
At the same moment when PM_SLP_S3_BUF_L is high, ALL_SYS_PWRGD must appear too, if you remove any other component from its rail; apart of R8167, of course.
As I said, let Q8150 out of board and test again.
U1845, U1930 and SMC are connected there too.
Remove all, apart of R8167 and SMC.
