820-00165 - No backlight.
gcain
Liquid damage all around U7701 and pin 3 & 4 on J8300 was 8.6v. Made me think LED Driver was dead.
Swapped it out and same behaviour.
BKL_EN = 3.1
BKL_PWM = 3.1
gcain
Take that back. Batteries just died in DMM.
EDP_PANEL_PWR = 3.3
JohnB8812
0.58 would indicate an issue near the LED driver for the switch trace. Inspect the LED driver for corrosion and make sure the A5 ball and the pads for balls 6 and 7 have continuity for feedback and switching.
gcain
Any voltage at J8300, pins 14, 18?
Check on the first seconds when board gets power...
::18 has 3.3v and ::14 sits at 2.6V (This is with a screen)
What should BKL_EN @ R7731 be?
I'm getting 4mV and at C7712 I get 8.59. (which becomes BKL_EN via R7731 right?)
I'll remove the LED driver and check all the traces if needed, but would prefer not to waste the chip if possible.
Serves me right for not measuring when it was off though, but the chip looked toast.
Did you try PRAM reset?
Check if there is image at least, as display should be detected (HPD signal is high).
"BKL_EN = 3.1
I'm getting 4mV"
So???
gcain
Just getting back to this job now.
PRAM reset already done, there is definitely a picture on the screen, just no backlight.
Will measure BKL_EN again from a few different places to see what it definitely is.
larossmann
BKL_EN should be around 2.7v . You had 3.3v then 0.04v, that is confusing. There is something simple missing here, bad feedback or switch, I imagine it is the switch trace that is missing due to 0.580.
0.511-0.546 is normal, 0.450-0.511 is bad feedback, over 0.556 is usually switch trace not making contact.
gcain
Thanks Louis, How can I check the switch trace?
Is that pin 5 continuity to D7701?
I pulled the LED Driver off again and pin5 has continuity to D7701.
Start from zero...
If U7701 already ripped, check continuity from all its pads to other components.
Next, aolder new chip and post voltages at Q7706/07 and U7701, power and controls.
gcain
Q7706
::1 = 8.59
::2 = 8.59
::3 = 2.86
::4 = 8.59
::5 = 8.59
::6 = 8.59
Q7707
::1 = g
::2 = 3.3
::3 = 0
::4 = 0
::5 = 3.3
::6 = 0
Change/resolder U7701.
Cjeck again EN and PWM, as its power too.
Check every resistor from return lines.
Measure on diode mode all 6 lines; you must get almost same value, no open line permited.
Don't forget XW7720.
And test known good assembly screen+video cable...
gcain
Thanks 2informaticos, Turns out my soldering was crappy.
The feedback pins on U7701 weren't touching properly.
Mark Solved please.
