820-00165 no install macOS Big Sur
iClub
Good afternoon, this mac only installs up to Catalina, when I try to install Big Sur it shows an error "Download another version and update again", but this installer works normally.
PP3v3_SuS when I force it to shut down it falls to 0V.
"Fsys is okay"
Do you mean is fixed with Medusa?
If ME cleaned too, then try anorher known good BIOS, clean ME of course.
iClub
To clean the ME region I used the CH341a and the INTEL ME INJECTOR.
UEFITOOL NE 57 to check the validation of the Fsys region.
Try to install Big Sur in the same SSD, but in other machine.
If succed, put back that SSD and lets see what happens.
iClub
At first, the SSD already had Big Sur. The system boots up normally. The issue is that it won't let you install Big Sur from the installer.
iClub
I can't read the Bios from the J6100 connector, so I removed it, to take the chance that it is interfering.
