I have a macbook in that has water damage, when the power cable is plugged in it goes green and then orange, no fan spin is seen.
Damage was sustained on R7523 (P5V_S4RS3_VFB1_R) which had gone high resistance and had corrosion attaching it to the nearby ground plane. This was replaced with another resister and corroded pad re tinned.
There was also corrosion between C1272 (PP1V05_S0_PCH_VCCACLKPLL) and C1297 (PP1V05_S0SW_PCH_VCCUSB3PLL).
There was also a small amount of surface corrosion, but no component damage around R5360
The following voltage readings were made :
PPBUS_G3H
8.6v
R5430
ok
PPBUS_S5_HS_COMPUTING_ISNS
8.6v
R5430
ok
PP3V3_S5
3.3v
R2094
ok
8.6v
C7434
ok
PPDCIN_G3H_ISOL
18.5v
R7005
not - 15.04v
PP3V3_S4
3.3v
J3501
not ok - 0.340v
PPDCIN_G3H
18.5v
R7012
not ok - 15.04v
PP3V3_SUS
3.3v
R8133
ok
PP3V42_G3H
3.42v
L7095
ok
PP3V3_S3
3.3v
Q4800
not ok - 0.063v
PP3V3_S0
3.3
C5450
not ok - 0.058v
PPVRTC_G3H
3v
C1910
ok
PP3V3_S0
3.3v
C5450
not ok - 0.58v
PP5V_S5
5v
C7400
ok - 4.97v
PP5V_S4RS3
5v
C7600
not ok - 0v
PP5V_S0
5v
R8063
not ok - 0v
PP3V3_S4SW_SNS
3.3v
C5460
no ok - 0.038v
PPBUS_G3H
8.6v
R5430
ok
8.6v
R5430
ok
PP3V3_S5
3.3v
R2094
ok
8.6v
C7434
ok
PPDCIN_G3H_ISOL
18.5v
R7005
not - 15.04v
PP3V3_S4
3.3v
J3501
not ok - 0.340v
PPDCIN_G3H
18.5v
R7012
not ok - 15.04v
PP3V3_SUS
3.3v
R8133
ok
PP3V42_G3H
3.42v
L7095
ok
PP3V3_S3
3.3v
Q4800
not ok - 0.063v
PP3V3_S0
3.3
C5450
not ok - 0.058v
PPVRTC_G3H
3v
C1910
ok
PP3V3_S0
3.3v
C5450
not ok - 0.58v
PP5V_S5
5v
C7400
ok - 4.97v
PP5V_S4RS3
5v
C7600
not ok - 0v
PP5V_S0
5v
R8063
not ok - 0v
PP3V3_S4SW_SNS
3.3v
C5460
no ok - 0.038v
