820-00165 no power
chrislewis85
Hi guys,
Got this 820-00165 which initially had minor corrosion around U7090, no green light. Found blown D7012, replaced and now got green light but no fan spin.
PPDC_IN is only 16.44v, PPBUS_G3H is 0.3v
Any idea where to go on this one?
"PPDC_IN is only 16.44v"
Looks perfect for me; in fact, its exact value depends by charger type.
Check diode mode to ground at PPBUS_G3H.
Post U7100 basic voltages: pins 1, 2, 3, 9, 12, 13, 14, 15, 17, 19, 20, 27.
chrislewis85
Hi 2informaticos,
Fair enough, I was expecting nearer to 18v thanks for clarifying!
Diode mode PPBUS_G3H = 0.130v
U7100:
1: 15v
2: 16.41v
3: 4.31v
9: 0.02v
12: 3.37v
13: 3.34v
14: 3.34v
15: 0.11v
17: 0.5v
19: 0.5v
20: 0.3v
27: 1.38v
"19: 0.5v
20: 0.3v"
Check diode mode too; may need to change U7100.
"I was expecting nearer to 18v"
"its exact value depends by charger type"
Did you check with 85W charger?
However, your board must work with 45W charger.
chrislewis85
Sorry, for some reason I though I had an 85W charger connected not a 60w, so 16.44 is obviously perfectly fine
Getting OL diode mode to ground on both 19 and 20
