820-00165 SMC_RESET_L signal at 0V
huzeafa
good day guys , this board is making me go crazy, SMC_RESET is 0V , but when I remove R5110 it goes high , when I put it back its low, I replaced it, but no difference , I tried with the SMC as well as R7100 to rule out a faulty U7100, and even R5100 replaced , all with no changes , please where do I go from here ? also the jtag is already removed even though was Spotless
Post all voltages for U5110.
Change C5101.
Don't forget to disconnect trackpad flex.
If still the same, remove U5110 and check if SMC_RESET_L goes high.
huzeafa
I have replaced C5101 but no changes , with U5110 removed SMC_RESET_L is high
below are the readings of U5110
U5110
PIN 1. 3.40V
PIN 2.GND
PIN 3.0V
PIN 4.0V
PIN 5. 0V
PIN 6.3V
PIN 7.3.3V
PIN 8. 1.1 and drops gradually
