820-00165 waters damage 0.03A
Try first to start in SMC bypass.
Next, check voltage and diode mode to ground on SCL/SDA lines of battery bus.
Post SMC/PM_BATLOW_L, SMC_ADAPTER_EN, SMC_PM_G2_EN.
Be sure to use original Magsafe 2 charger.
yobad
3V3_S5 3.3v
PM_SLP_SUS_L 3.3v
3V3_SUS 3.3V
i tried SMC Bypass no change
what is RTC signal ?
RTC_RESET_L 3.3v
PCH_SRTCRST_L 3.3v
PCH_INTVRMEN 2.5v
PCH_INTRUDER_L 2.5v
Check if the board starts disconnecting LIO flex.
Post PCH_DSWVRMEN and PM_DSW_PWRGD and PM_RSMRST_L levels.
Check if PM_PWRBTN_L reacts when trigger SMC_ONOFF_L signal; use R5115/16 pads.
yobad
PCH_DSWVRMEN 2.7v
PM_DSW_PWRGD 3.3v
PM_RSMRST_L 3.3v
PM_PWRBTN_L 3.3v it go to 0.4v when it trigger SMC_ONOFF_L.
it didn't start without the LIO flex.
