820-00426 Battery charging issues
No-Clean
Clean board battery charges to 100% fine, discharges down to around 50% just fine, but around 50% the battery icon turns red, battery stays around 50% for a little bit then it drops to around 5%, computer sometimes also restarts randomly.
2 Known good batteries and same exact result.
I checked board and looks clean, also tested with different external OS and same thing.
Machine restarts only when battery is connected?
Same with charger plus battery, even above 50%?
Did you test its battery in other machine?
No-Clean
We have not been able to replicate restart problem at all.
We have only tested with battery only.
2 known good batteries.
Tested with new chinese batteries?
I'm not sure about your reply.
The problem didn't appear with its battery installed in other machine?
No-Clean
I don't have another machine to test, we have been using this vendor and same batteries for years, they are not cheap and work great on all other machines in the past.
