820-00609-A - Random crash
samstown
Hello,
I got this iMac 5K 2017 from another shop, sometimes it works, sometimes it doesn't.
If I press power button, it start, I can log... then after fem mins sometimes it crash the reboot then I can login again and it will work, stay alive for the whole night.. then I shut it down... and when I press power button, it won't start. I unplug power cord, try couple of times then it will boot again, crash and work... It's never the same scenario....
I've unplugged camera, I've replace power supply, I did SMC reset, I've removed CR2032... still the same. Sometimes it works, sometime it doesnt.
If I unlugged HDD, try another SDD, try without HDD/SSD, same... sometimes it will start when I press button, sometimes not.
MacOS 12.6.2
Radeon Pro 570 4GO
Intel Core i5 3,4 GHZ
RAM - 64GB 2400MHz DDR4
Thanks
Sam
samstown
thank you, looking at other post, it looks like similar problem where solved by clean me, I'll search how to do it.
samstown
What would you recommend, desolder the BIOS Winbond chipset to flash it or solder a connector on motherboard and then use Medusa ?
Remove the chip, connect it to Medusa and clean ME.
A4564/70/76 are the cheapest adapters to use with; also A4064.
I use A4064/69 many times...
samstown
Clean ME didn't help. I mount mb back, plug power cord, computer turns on (two leds only) but no image, unpluged power cords, keyboard, ,tried several times... nothing. Unplugged cable...wait 2 hours pluged it back, press power button...after few seconds it boot to login screen. I entered pw.. it crash.. black screen.... unplugged power cord, plugged it back.. black screen.. nothing. crap...
