820-00840 5v not turning on
Yoel Ren
Guys, he's obviously checking for a short IMMEDIATELY after powering off the board. OP, let the board discharge for 2-3 minutes and then check for short on ppbus. It will show a short if you check it immediately after removing power. If it shows a short, then check again after 30 seconds. Keep checking and I guarantee the "short" will go away.
yes this is the problem, thankss for this..
I only get 5v, it doesnt switch to 20v
R7020
pin 1-4 is 5v
L6995 : 3.4v
f7000 : 48mv, thats a 0 is it
If board works on battery, then you still have a problem with input stage.
Try removing redriver chip.
Be sure CD3215 chips are both correctly doldered.
Post diode mode to ground on all their power rails.
Wait 30s before measure in diode mode, after power is removed (even battery).
