820-00840 keyboard ant track pad not working
Looks like poltergeist.
If you lost 20V on USB-C port after touching the board, could be an induced problem.
Missing 1V1 LDO now, points to U3100/200, U2800/90, or something on their area.
yair37
o.k finally i was get to f...20v! but....its on just without battery (but falling at 60% load) with battery PPBUS_G3H 0.4V AND show 20v 0.3A ant not turn on.
yair37
the same....work just without battery apple logo 70% loading and then shout of and then turn on to the massage "your computer restarted because of a problem. press a key or wait......"
Gets stuck in progress bar w/ and w/o battery?
Did you try with known good working battery?
Test it booting USB macOS.
Also test starting in safe mode and SMC bypass too.
yair37
Moment of history ? The Mac was work fine just no keyboard and trackpad.
After all 5v stuff and back to 20v...With battery it’s dead and PPBUS_3GH 0.4v(also try good know battery but the same) it’s turn on just with charger alone(no battery)! Apple logo with loading bar, stuck at 70% and turn off. I was tried different ssd but the same.
Will try Safe mode and update. But the battery thing is wired.
yair37
update:
just charger no battery work with safe mode(not all the time)
i was put new battery new its look good(20v 2A) but when i connect the charger to turn it on i just hear the charging sound and dead...
yair37
No, just battery not connected...but now when i put the battery "data" cable the charger is 5v pulsing...i thinks there is something at the battery line...
Shouldn't be USB-C issue, as the input power switches to 20V correctly.
I suspect more for a SMC sensor issue.
But you've said didnt' start in SMC bypass mode, very strange...
Many times explained on the forum and Google also helps.
BTW, once battery and charger are both removed, SMC reset is done; no need to do it through keyboard.
But is not the same as starting in SMC bypass mode!
yair37
update: i was finely get good u3200/3100 ic's...put them and now i get 20v but 0.03A
and ppbus_g3h is short(0.02) i was try to find what getting hot but nothing. how can i find from where is the short?
How did you try, injecting voltage into PPBUS_G3H???
Compare exact ohm resistance (not diode mode) with all coils.
