820-00923 No image
No-Clean
Clean board no water damage and no more history, I have image on external screen.
EDP_PANEL_PWR_EN and PP3V3_S0SW_LCD and PANEL_P5V_EN and PANEL_P3V3_EN come on for about 1 second then leave
All tests are done with good LCD connected and new LCD flex.
Seems to be a problem with CPU eDP video output.
It should detect LCD presence and maintain the voltages, once DP_INT_HPD goes high.
piernov
Moderator
Can check diode mode to ground on EDP_INT_AUX_N and EDP_INT_AUX_P to see if the transceiver inside the CPU is completely dead at least.
No-Clean
Thanks @piernov EDP_INT_AUX_N is OL and EDP_INT_AUX_P is 0.211 measured in diode mode, I dont have another board to compare, any input will be greatly appreciated.
You must get almost same value on both lines; red probe connected to ground.
The CPU eDP output is damaged...
