820-00928 No Power
iClub
Good afternoon this mac has suffered oxidation in the U4200, U3500, and U3100 regions. I replaced the oxidized components, it worked for a while. The customer returned with the defect of an unexpected shutdown. Now no PPBUS.
I had made a post earlier.
U3200 mode diode/ Voltage
PP1V8_UPC_XB_LDOD 0.487V 1.80v
PP3V3_UPC_XB_LDO 0,507 3,33v
PP1V1_UPC_XB_LDO_BMC 0,520V 0v
PP1V8_UPC_XB_LDOA 0,527V 1,82v
U3100
PP1V8_UPC_XB_LDOD 0,491V 1,82V
PP3V3_UPC_XB_LDO 0,511V 3,33V
PP1V1_UPC_XB_LDO_BMC 0,522V 0V
PP1V8_UPC_XB_LDOA 0,530V 1,79V
UB400
PP1V8_UPC_TB_LDOD 0,487V 1,8V
PP3V3_UPC_TB_LDO 0,512V 3,2V
PP1V1_UPC_TB_LDO_BMC 0,510V 0V
PP1V8_UPC_TB_LDOA 0,527V 1,8v
UB300
PP1V8_UPC_TB_LDOD 0,489V 1,8v
PP3V3_UPC_TB_LDO 0,513V 3,31V
PP1V1_UPC_TB_LDO_BMC 0,522V 0V
PP1V8_UPC_TB_LDOA 0,528V 1,8v
PPBUS 0,123V
PP3V3_G3H 0V
PPVIN_G3H_P3V3G3H 0v
PP20V_USBC 20V only where the charger is connected
How do you get 20V without 3V3_G3H?
This is really strange.
"PP3V3_G3H 0V
PPVIN_G3H_P3V3G3H 0v"
Check again these voltages; especially when you get 20V at USB-C meter.
If not present, check diode mode to ground on both.
iClub
mode diode
PPVIN_G3H_P3V3G3H 0V,no pulse. 0,557V
PP3V3_G3H 0V, no pulse 0,370V
FB200 20,11V
I had changed u3100 earlier, I forgot to comment.
iClub
R5210, R3035, and R3035 are not on the board. Does it come on the board or is it missing?
So you have problem located in USB-C areas.
More components affected by corrosion.
Post C3101 voltage.
Connect charger to its corresponding port.
iClub
Suddenly the mac turned on using another charger.
I left it in tests and out of nowhere it turned off and won't turn on anymore. It is intermittent, out of nowhere it turns on.
I would like to know if the components I already replaced are U4200, U3906, U4401, U5850 and U3100 ?
PPBUS 12,6V
