820-01041 no trackpad or keyboard
Kyle93
Arrived with L6700 blown up. Customer claims it smoked after changing battery. Replaced L6700 soldered direct to pin 1 of C6700 and a wire ran to pins 26 and 24 of J6700 but still no trackpad or keyboard. Also tried new trackpad.
What should be checked next??
Kyle93
This recently came back for the same problem. Trackpad and keyboard not working. After reseating cables trackpad is working again but still no keyboard.
5v present pins 26 24 and 23 on J6700
Keyboard I2C bus connects with trackpad.
You must test with known good keyboard, as it has embedded electronics.
Kyle93
Tried known good keyboard but still no change. Trackpad works but no response from keyboard.
Try good trackpad flex too.
Be sure to have good contacts at J6700.
Check voltage and diode mode to ground at I2C_KBD_SCL/SDA lines.
