820-01521 PP3V3_S5 = 0v
No-Clean
Clean board I get 20V on charger and 12.6V on PPBUS, here are some more measurements:
PPBUS_G3H = 12.63V
PP3v3_G3H = 3.4V
PP1V8_SLPS2R = 1.8V
PP1V8_AWAKE = 1.8V
PP1V1_SLPS2R = 1.1V
PP0V8_SLPS2R = 0.79V
PP3V3_AWAKE = 3.4V
PP1V2_AWAKE = 1.19V
PMU_PVDDMAIN_EN = 3.3V
P3V3MAIN_PGOOD = 3.26V
PP3V3_G3H_RTC = 3.0V
PCH_RTC_RESET_L = 3.0V
P5VG3S_EN = 1.8 V
PP5V_G3S = 5.4V
PP3V3_S5 = 0v
I also tried restoring T2 on both Catalina and Big Sur and got error 9 something....
As you get all SLPS2R and AWAKE voltages, machine should enter into DFU.
Check SSD voltages too.
Inspect audio board for liquid sign, on both sides.
No-Clean
Board does enter DFU, but fails to restore/revive in both Catalina and Big Sur
Audio board is clean and flex too.
PP2V7_NAND = 2.5V
PP1V8_SSD = 1.8V
PP0V9_SSD = 0.9V
SSD0_RESET_L = 1.8V
There could be a problem with T2 then.
Did you check for short on all big coils?
No pulse at all on 3V3_S5, when trigger PMU_ONOFF_L?
No-Clean
No shorts on any of the bog coils.
PMU_ONOFF_L is 12.6V how do I trigger it, sorry for the novice question.
TCRScircuit
Super Moderator
PMU_ONOFF_L should not be 12.6v!!!!!! You are measuring wrong, or you have a very bad problem somewhere.
No-Clean
I can reball T2 no problem, but if that doesn't solve the issue can the T2 chip be replaced from a donor board?
