820-01598-06 Reboots and slow
prodigy83
My reference only: REF1131
Board has liquid damage.
Computer turns itself on even if I hold the power button down to shut it off. Just keeps turning itself back on.
There is no OS installed.
I try to run Apple diagnostics and it wants to connect to the internet, I type in the wifi password and it never connects, just spins.
The mouse and keyboard are slow/choppy. The fan does not spin fast, it does not spin up at all but from what I can remember, the fan would spin up after being turned on for a while.
Battery seems fine as I unplug the charger and the computer stays on.
Keyboard light is coming on.
I tried getting the computer in to DFU mode via the keyboard method and no success. (Not sure how to place in DFU mode without keyboard).
I am assuming this is a sensor issue but I have no clue where to look to be able to tell?
Inspect audio board/flex and touch ID for corrosion.
Check diode mode to ground on T2 data lines from J6600.
prodigy83
Flex and board look good.
I am not 100% certain which ones are the data lines, nevertheless T2 data lines? I am assuming the data lines are the ones with "SPI" at the beginning?
SPI_MESA_MISO_CONN: .494
SPI_MESA_MOSI_CONN: .516
SPI_MESA_CLK_CONN: .515
You should test in other shell, with known good TP/KB and touch ID.
PMU_ONOFF_R_L_CONN should stay high and drops only when press the power button.
prodigy83
I did confirm with another iCloud locked motherboard that the shell, everything is working fine.
I did however decide since J6700, the clip was damaged and I had been using kapton tape on top to make it snug. I ended up replacing the entire J6700 connector from a donor board. While doing so, I noticed pin 14 "I2C_KBD_SDA" the pad was damaged. Not sure if I did that or if it was like that the entire time. Anyhow I repaired the pad with a slug. But after doing so, I am experiencing the same result.
Just also checked for continuity from J6700 pin 14 to J6701 pin 8, and I do have continuity. What else could this be?
Try starting into diagnostic mode.
Machine allows you to boot USB macOS?
It should automatically enter DFU, if you reflash Soc ROM.
prodigy83
While holding down D, it takes me to the Starting Internet Recovery Screen, then it wants me to connect to the wifi. I type in the password for the wifi, and it just sits there spinning and never connects.
Well, when I hold down the Option key, it does detect the macOS image, I choose it, and then it goes back to booting from internet recovery, I get to the wifi password screen again, I type in the password, and it just keeps spinning.
I did get it to go in to DFU mode, so I did both a restore and revive, this did not help. Still need to do the Soc ROM? I tried googling for this file but I am not locating it. I googled "820-01598-06 Soc ROM" without the quotes.
prodigy83
Update:
J6700 voltages while running with the lid closed:
Pin 18= 1.7v
Pin 19= 0v
Pin 20= 5.1
Are we a bit low on pins 18 and 19 with the lid being closed?
Reflashing SoC ROM will not help, if already completed DFU without errors.
Something more has been affected by corrosion on the MLB...
prodigy83
C7652 pin 1 Is spiking up and down, 1.99v to 0v, there was burnt sides around this area. I take it C7652 is not supposed to do this? Bad U7650?
Replaced the following: C7691 This is spiking up and down too 3.2 to almost 0v, C7652, C7698, and R7695 all replaced.
I get 12.3v to 12.6v on Pin 23 on U7650.
L7030 is going from 12.3v to nothing up and down. The board never did this before.
Don't bother checking L7030 on these boards; is irrelevant.
Pins 19 & 20 are tied together at J6700.
Board stays on with PPBUS_G3H fluctuating 12.3-12.6V?
Check it disconnecting J6700.
prodigy83
Its not powering up now but I get a healthy 20v PPDCIN_G3H_CHGR up to the mosfet Q7030. I tried reflowing this but I think it may be bad?
I just removed L7030 to isolate the issue and pad 1 of L7030 jumps up and down from 2.1v to 1.6v.
Took up Q7030 also and pin 1 is up and down, its is looking like possibly U7000.
prodigy83
Aha, sorry. I am used to the old power aliases.
The USB-C port does have slight damage but as long as I have been scewing down the connector plate, it stays fine at 20v. Upon replacing U7000 I do have 3 pads missing but they say NC, so I am assuming these don't matter. The pad numbers missing for U7000 are: F2, F3, and H4.
USB-C meter does show 20v.
PPBUS_G3H shows slightly up and down: 12.29-12.59
PP3V3_G3H_RTC is stable.
PP3V3_G3H is a problem, it drops from 3.3 to .9v.
PP5V_G3H_LDO is also unstable. U7650 problem?
When in DFU, PPBUS_G3H still fluctuates?
Compare diode mode readings on all big coils with known good board.
Cycling lower power rails can be caused by a short somewhere.
