820-01598 stop working
bartech
on usb voltage tester it take 5v but if i flip usb c cable to other site on voltage tester black screen, only one side of usbc work and its whit two of usb at mainboard.
g3h-0v. i change u700 but the same ampers going up and down 4-3A,
When I ask about DIODE MODE, I expect something like "0.xxx".
Don't write end "V" in such case.
Multimeter reads the voltage induced by itself on the mainboard; in diode mode!
Is not a voltage reading, like when power is applied.
Avoid any confussion, please.
Do you mean OL, or 0.000 for XA_CC1/2?
"usbc_xa_cc1- 491
usbc_xa_cc2- 570"
Too big difference there!
The first suspects are DZ3302 and U3100.
Low chance of C3113 leakage.
bartech
i change to big dot but still a problem, that u3100 work on one side of usb c , when i flip the cable black screen
on voltage tester
usbc_xa_cc1- 577
usbc_xa_cc2- 577
bartech
i change u3100 fron the same working mainboard and the same,
i check d3399 and on site of cabel working i got 5.17 on other i get 0v and black screen on voltage tester.
bartech
i check and dont have connection on usbc_xa_cc2 i wire from tp[1]usbc_xa_cc2 and get connection to c3114 but still black screen on voltage tester
Check diode mode to ground at C3113/4; you should get very similar readings.
Also check continuity with corresponding pins of J3300.
