820-01700 A2141 not charging
Soji
The board only on desk draws (charger only)5v 0.27A
PPBUS_G3H=12.32v
PP3V3_G3H_RTC=3.3v
System boots with batteryand charger and stay on with battery :pPBUS_G3H=12.32v
PP3V3_G3H_RTC=3.3v..
But not charging..
Did you test the board alone on the desk with original 96/140W charger?
Check voltage and diode mode to ground on SCL/SDA lines of battery bus.
When booted with battery, macOS shows battery percentage?
Check UPC_I2C_INT_L.
You still have problems on USB-C areas.
Soji
It shows battery percentage....
The board first came in dead i found short on PP5V_S4_UBC then passed current through it found U3100 get in hot and i replaced it..
Short gone
