820-01700 water damage PPBUS_G3H 0.25 dido mode.
yair37
water damage mostly on PPBUS_HS_CPU.
clean all but PPBUS_G3H 0.25 on dido mode. can see any bad big cup.
Post diode mode reading with black probe at ground too.
Check if you get similar readings on any big coil.
Which coils???
I doubt all the coils from MLB give the same readings to ground!
A coil with similar reading like PPBUS_G3H, can denote shorted high-side MOSFET.
Do you mean coils directly connected to PPBUS_G3H, why?
Did you expect to get different readings in different points of the same power rail???
With black at ground, you should get OL in diode mode at PPBUS_G3H.
Again, compare with diode mode to ground (both directions) on all big coils from secondary power supplies.
Just for example, L8102, L7700/01, L7600/60, and many more...
yair37
L330-
cpuvr_swsa
ppvccsa_cpu_r
there was water damage at this area..but i was clean ant all the area look good.
yair37
it was u7370 that short..replace it.
now..20v on charger ,one fan spin, no screen and no keyboard activity.
If already got correct PPBUS_G3H, no reason to check diode mode to L7330.
My previous post was writen before, but appeared after yours.
Check voltage on the big coils now.
yair37
first the board no turn on(fan spin) just with the charger only with charger and battery cable with and without battery.
all the big coils has the right voltage except PPVIN_S0SW_LCDBKLT- 0.6V with and without screen connected.
yair37
the fans not spin when i plug the charger(without battery or battery cable connected.
they start to spin just if the battery or just with the battery ribbon cable are connected to.
No idea what kind of translator are you using, but doesn't help at all...
I really don't understand what you mean to say about battery and its data cable.
When the board turns on, what is L7211/21/31 voltage?
No need to check on the 3 coils; one is enough.
