Fixed - R5222 was blown replaced it now PPBUS_AON is back on 12.27V.
I noticed that PP3V8_AON_VDDMAIN is just at 2.8V (too low) instead of 3.8V.
Step 1. Check for a short to ground on PP3v8_AON_VDDMAIN. C5887 is a good place to measure from. Normal diode mode to ground reading = ~.350.
- Value: 0.313
Step 2. Check the enable signal to U5700, P3V8_PWR_EN.
- P3V8AON_PWR_EN = 5V
- CHGR_MVR_EN = 5V
Step 3. Ensure that the VIN (PPBUS_AON) is making to U5700. Occasionally a via or trace can break resulting in a voltage not making it to some parts of the board. PPBUS_AON can be measured adjacent to U5700, on C5704 or C5804.
- PPBUS_AON (12.27V) is present on those two caps.
If all above findings are negative for issues, replace U5700.
- Should I proceed with that step or do you have any other idea?
I might have (accidentally) touched P3V8AON_PVCC and PPBUS_AON with my multimeter (P3V8AON_PVCC is now 0.085) - PPBUS_AON is going from 3V-12V ... I think it's time to replace the U5700....
