820-02016 not turn on
andrespi
I don't know how this type of board works, can you help me with the measures to take; only 5v 20ma en tester
andrespi
THE ONLY WAY TO DFU, IS WITH ANOTHER LAPTOP M1 CONNECT IT? client said that it discharged the battery and it did not turn on again
You can do it even with older USB 3 model, using correct cable.
Original Apple Tunderbolt 3 cable, using another USB-C MacBook (2016, or newer), is the recommended way.
andrespi
any story? previous technician reballed the 2 cd3217
a question I have cd3215 other logic board macbook air 2018 retina, it is compatible with logic board 2020 CD3217?
where buy cd3217?
Just look at schematics to understand not compatible chips.
If no donor board available, try Aliexpress; pray hard in such case.
Maybe not worth to invest time in this machine, if someone else already worked on it.
andrespi
change cd3217 and the equipment turned on, but it does not recognize the battery, an x appears, will it be a battery problem or a chip change, I do not have batteries for this model to check, any specific test o measure?
Check diode mode to ground on SCL/SDA lines of battery bus.
Known good working battery may be the only way to discard battery issue.
