Palhano
The Mac works fine. But it doesn't turn off when the screen is closed. The hall sensor fails and the Mac turns on (as if the screen had been lifted). If you leave the Mac turned off, with the screen open, it doesn't turn on.
I checked the board, everything is perfect. I looked for the sensor to replace, but I couldn't find one to buy.
If I remove it, would the Mac work normally? In older models, there is a method to connect the HALL_sensor with the SMC_LID, would this model have something similar?
