820-02098 power cycling
Kyle93
Which secondary power rails specifically should be checked? I do not know these newer boards as well as the older ones
Kyle93
PP3V3_S2 3.2V
PP3V3_AON 3.3V
PP5V_AON_P3V8AON 5V
PP1V8_AON 1.8V
PP1V8_AWAKE 1.8V
PP3V8_AON_SPMU_ISNS 3.8V
PP1V5_AON_VCORE_SPMU 1.5V
PP1V2_AON_SPMU 3.2V
P1VP2_AWAKESW_BLC 0V
PP0V72_S2_VDDLOW 0.72V
Bad U7700 from P1VP2_AWAKESW_BLC 0V????
What said the client about how the problem appeared?
With battery connected, PPBUS_AON drops to 0V in the same rithm of USB input?
Kyle93
There was minor liquid damage but only in C5210 area. Nothing was even shorted or looked damaged except some very minor corrosion on the board itself not touching any components.
PPBUS_AON drops to 4V during power cycle of USB input. Goes up to 12.33V when first plugged in, drops to 4V then back to 12.33V e.t.c
