820-02098 water damage, no PP5v_S2_MAIN
devoniodd
All LDOs out works (both U8100 and U7700) except for 3V3_AON, could not measure the coils, I can't reach the contacts porperly, I'll get nwe probes. Any idea on how to get a new U8100?
devoniodd
So I think I found a replacement for my U8100. I thought don’t understand if/how the absence of 1V8_S2 and 1V2_S2 could be caused by a faulty U8100 and if not so what could be the problem. Also as you pointed out U8100 has some platform-dependent pins, what exactly does that mean? I found a A2442 donor board which is the same model, but not sure if it’s a 8/14 or 10/16 cores, could that be a problem?
If is same model, is the same platfom, so you can change it.
U8100 is master PMU and must generate 3V3_S2 by itself, without an external control.
It only needs 3V8_AON to generate 1V2/1V8__AON and 3V3_S2.
Also generates 1V5_AON for its core and 1V8 for SRAM.
devoniodd
Ok, my problem is that they seem glitchy, a jumping tensions (always under 200mV). Can the be caused by U8100 on 1V8_S2 even though it is generated by U7700? Or is this a sign of a faulty U7700?
